sdianel_-acct_c
Jan 09, 2016Explorer
We don't have a Monaco but it's my understanding that the Aladdin System was only a monitoring system like Silverleaf. The slide system on our 2005 Country Coach is electric Power Gear by Lippert. They also make hydraulic. Although Country Coach was out of business for a few years, we have not had any problems finding someone to work on our coach components. Search on www.monacocoach.com and locate a dealer or service center. They should be able to assist. I agree that you should just have it checked out and not get rid of what's still working. On our 2005 coach we had intermittent slide problems. If electric, check the motor and gears, if hydraulic check the reservoir. We found on our coach that we had loose electrical connections in the rear electrical bay that caused the problem. We also have fuses and-or limit switches in the slides that prevent failure. If these limit switches trip, you must wait a few minutes before trying it again. We also had a loose wire going to the slide out motor in the living room slide. Also your coach batteries must be charged. We turn the ignition key to the "on" position when extending or retracting our slides.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
