Just came home with another travel trailer. 2015 Jayflight 32 BHDS. It has a KIB monitor panel with the switches for water pump, electric and gas water heater operation. All of the switches function, ...
Not sure which panel you have but the link above has several to choose from. All the indicator lights are LEDs so they should still work. The lights in the switches are another story. They're probably incandescent lamps and often burn out. Get at the panel and check for voltage to the lamps when they should be on. It might be easier for you to replace the panel.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
