Just came home with another travel trailer. 2015 Jayflight 32 BHDS. It has a KIB monitor panel with the switches for water pump, electric and gas water heater operation. All of the switches function, ...
Problem solved. I sent an email to KIB the manufacturer of the panel last night. I was advised to check for a bad ground, took the four screws out removed the panel and tightened up the connector on the white ground wire, everything is working perfect.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
