BFL13's avatar
BFL13
Explorer II
Jun 28, 2022
More on LFP Charging
Some "sales" statements here, but also some possibly good info of interest.
One thing is they found longest life (most cycles) was to charge at 14.4v but at lower amps at 0.3C.
Some LFP owners on here ISTR have taken to charging at lower voltages hoping for longer battery life. Perhaps it needs to be established which is correct--lower amps or lower voltage?
They say 14.4 vs 14.6 to reduce stress, and recommend their own charger (of course!) which is single stage 14.4--BUT they say shut charging down-disconnect- once the charger says the batt is full. (light comes on---what makes that light come on? oh well)
They are strongly against floating! see why.
Anyway, it covers some of what has come up on here lately.
https://dakotalithium.com/2021/09/22/how-to-charge-dakota-lithium-and-lifepo4-batteries/
  • pianotuna wrote:
    At 0.3 C the "rapid charging" feature disappears compared to my favorite chemistry.
    I think it is great that folks can "roll their own".
    Can the bms be set to limit current to 0.3 C for charging?
    Li are excellent except in the cold.
    166 amps is too slow?
    BMS does not throttle. On or Off only.
    Only if the Li is allowed to get cold.
  • At 0.3 C the "rapid charging" feature disappears compared to my favorite chemistry.
  • A guy here was selling his Dakota 200AH for $500 (Can) so I was looking into it. Could not find the BMS specs for cut off voltages. Some specs info only.
    (I got nervous about buying used because how can you tell if it has been "damaged" by whatever usage? Didn't need it anyway, but tempting price. Somebody got it, so good luck to him.)
    It does seem LFP advice can be "brand specific" even if they all have similar type cells.
  • Yes this would have you believe lithium is very finicky and unforgiving. I can see their point to control the charging with the cacophony of various chargers on the market. Hard to comment exactly unless all the BMS parameters are published. All the more reason to build your own and have far more flexibility.
  • Their info reads the same as others. It looks like they need 14.4 for 3hours to balance the cells with what ever their bms is inside.
Having RV issues? Connect with others who have been in your shoes.24,331 PostsLatest Activity: Nov 04, 2025
