Solar power total for six days of rainy weather Friday thru Wed
1120.7 watt hrs, 82.91 amp hrs
Watt was surprising, was during yesterdays "Wednesday" brief sunny period, the solar out put hit a peak of 16.61 amps 233.3 watts, likely it only lasted seconds,and I'm guessing it was the combined effect of three things clean rain washed panels, clear clean rain washed atmosphere, and the fridge cycling on causing a inverter surge with corresponding dip in battery voltage, letting the panels/controller hit a momentary peak
whatever the conditions causing this, it is the highest amps controller out put reading recorded so far
