Salvo
It might be time to get up on the roof and clean the panels
And check the adjustments on the blue sky 2000e controller
I could reconfigure the panel wiring to series parallel to raise the solar voltage into the controller
But we use so much power that i run the generator every morning
The solar charged is in addition to the converter charging not in place of
The solar did that much along with
all the amp hrs from the genset powered converter
maybe if i had too i could manage with the generator charge every other day but i world be more likely have to deal with sulphation and stratifcation
This way the batteries are fully charged everyday
My solar is not enough to fully charge my batteries everyday our power needs are too great
Maybe after i connect the second bank i can try a solar only day and see how much the solar can provide
