Hi all,
Sunrise 5:30 a.m. location Regina, SK 50.4027,-104.602597 , some shading from bare tree branches.
Progressive Dynamics 40 am converter in "normal" mode reading 13.6 volts and drawing 17 watts as measured with a kill-a-watt meter, so the battery bank is fully charged.
05:50 0.1 amps volts 13.7 temperature 2 C
06:00 0.2 amps volts 13.7 temperature 2 C
06:30 0.5 amps volts 14.6 temperature 4 C
07:00 0.6 amps volts 14.9 temperature 5 C
07:30 0.6 amps volts 14.9 temperature 7 C
08:00 0.6 amps volts 14.9 temperature 8 C
08:30 0.6 amps volts 14.9 temperature 9 C
At 9 am I decided to power up the inverter and place a 28 amp load on the battery bank.
09:00 1.7 amps volts 13.6 temperature 12 C
