on Monday the 8th i ordered (3) new 100w windy Nation poly panels thru Amazon
$137.99 each
they were sceduled for dilivery on Wed june 10,
the first one (only one) arrived yesterday thurs June 11, one day late,
and i Installed it Today, started around 9am finished about 1PM
removed one unisolar 42w and installed (1) 100w
now the other (2) panels arrived this afternoon, and i intend to install on Sunday
replacing (2) more of the unisolar panels
this will still leave me 6 unisolar panels totaling 296w plus the TWO original Siemens 54w panels and the (3) new 100w
approx 704 watts total when the new configuration is complete
correction total wattage is 679 watts
for all previous panels and this one
i bolted the mounting feet (brackets) to the panel with 5/16 nut & bolt, but this can lead to a lot of work if you need to access the wiring or clean under the panels, (my panels are fixed not able to tilt)
for the next two panels i have decided to use my NUT RIVET TOOL
riveting 1/4 nuts (biggest ones i have) to the inside of the frame so i only need to bolt/screw the bracket to the side of the panel from the outside, access to underside will not be needed if i need to remove the bolt and clean underneath check connections etc..
if this works out ,, at some point in the future i will do this to all the panels
