one of (2) house banks..and mainly used together (unless i am doing maintenance on one of them )
new replacement bank in the OEM tray
they replaced the 12v Flooded wet cells,
lower amperage, only because, i could not get these in a larger size surplus
and i wanted high quality AGM, i was wearing out the wet cells and replacing them under warranty
the other bank, the (4) CD technologies 139ampHr AGM's are still in use, will be 4yrs next month,
still working, but NOT quite the capacity they had when i bought them,
they load tested pretty fair, last test about 6 Mo ago
IF i could have found some more of those, i would have bought them
i was just out side this morning tweaking the solar to maintain the correct voltages, i was actually set a little low ( i thought i was set high )
cycle charging specs call for 14.1 to 14.8
the only time my system gets to float is IF they are fully charged and the generator is running the A/C
even if all lights and fans are off the inverters are still IDLING, there is almost never a dead rest float condition, and i had not got the Xantrex C40 set up correctly
right now I've got the batteries and fridge on Solar and the A/C on generator
and I'm testing and adjusting the Solar, measuring the voltage At the Batteries
