MrWizard
Feb 20, 2016Moderator
Both
It is what is going into the batteries
You might have 50 amps solar capacity under ideal conditions
But if if the batteries don't need it then they are not going to take it
Also early in the morning the batteries will be hungry, but the panels won't have enough sun to produce full power
So all they can produce is a few amps
So yes the panels are producing 7 amps not more , only 7 because
That is either all they can produce at that moment or because that is all the batteries will accept
That IS the amount being produced and sent to the batteries
