- MrWizardModerator
pianotuna wrote:
It is fairly easy to test this. In good solar conditions, turn on a large load. If the display shows a larger number--then you know it is set to measure what is leaving the charge controller, and not what is coming in.
sorry PT
yes the load might show an increase, but
the controller ALL ways shows what is being produced and sent to the system
NOT what might be available,
think about the electric meter on the side of the house
it shows what you are using
NOT the MEGA WATTS available on the utility power line
if the batteries and house circuits only take 7amps, them that is all that is being produced, not 30amps , that extra difference is
"Potential Power" not being produced or utilized
if it was being produced and not used the controller would be dissipating it as heat...OUCH
it is voltage VRS battery circuit resistance , which limits the flow to 7 amps, even if more is available
if you turn on a load and it goes up then more is available
if the flow does Not increase, like late afternoon or early morning, then that is all the solar energy available
but always the meter shows BOTH... what is going to the system, IS what is being produced - CA_TravelerExplorer IIIIt should be the controller output amps. Those amps supply both house loads and then battery charging. So you might have 3A for house loads and 4A for battery charging.
- pianotunaNomad IIIIt is fairly easy to test this. In good solar conditions, turn on a large load. If the display shows a larger number--then you know it is set to measure what is leaving the charge controller, and not what is coming in.
- MrWizardModeratorBoth
It is what is going into the batteries
You might have 50 amps solar capacity under ideal conditions
But if if the batteries don't need it then they are not going to take it
Also early in the morning the batteries will be hungry, but the panels won't have enough sun to produce full power
So all they can produce is a few amps
So yes the panels are producing 7 amps not more , only 7 because
That is either all they can produce at that moment or because that is all the batteries will accept
That IS the amount being produced and sent to the batteries - pianotunaNomad IIIMy solar controller shows what is being sent to the battery bank.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
