CT_WANDERER's avatar
CT_WANDERER
MorningStar TS45
I have the Morningstar TS45 PWM controller on my solar system. It is working great I am happy with the system. Just questioning on of the reading I get on the remote panel. At time, it show PWM XX% on the lower right side. What is the percent sign show or tying to tell me. I see it bouncing around. But panels are in the light shade for now. Thanks Gary
  • I assume it is the PWM time slice. If so it should be 100% in bulk and taper during absorption.
    I believe you can program it to drop to float by the percentage.
  • Likely battery soc %.
    My Tracer mppt has an option of 100% soc, or voltage comp., for when the controller 'thinks' the bank is full. I set mine to voltage comp, and soc went up and down with system wattage, from 50-100%, while the bank was in the high 90's. Problem with solar is, it's up and down like a toilet seat on new years eve. My thinking is, the controller couldn't possibly estimate soc, based on ever changing data, as volts and amps are constantly changing.
  • jrnymn7 wrote:
    Are you referring to one of these?
    Remote Meter
    Manual
    Yes that is the meter I am talking about. On the lower right side of the meter is where it gives Charge State Information. It tell if it is in Bulk, Etc. I seen it showing PWM XX%. With the numbers going from 45-98%. I am just trying to understand exactly what these number stand for? Gary
