Almot's avatar
Almot
Explorer III
Mar 09, 2024
Mounting a small amplifier under cabinet?
Bought Fosi BT20A , like it so far.  To my ear it beats an average home theater receiver, being also very small. The only good place is under cabinet.  I am out of ideas how to mount it.  I could buy a plastic clamshell similar to one holding my RV radio under the cabinet but this shell is huge, Fosi is tiny, 4" x 1.6" front, 6" deep front to back, weighs 1 lb.  It's all metal, no vent holes, does get warm, not hot.
Are there any thick double-side adhesive strips to leave a spacing 1/4" or so from the cabinet and hold it without shaking?  Eventually I could make an ugly plywood tray and paint it black but maybe there is an easier way?
  • Are the feet removable? Might be able to attach the brackets there if they do. Sometimes you can pry out a rubber plug to find a screw.
  • PatJ's avatar
    PatJ
    Explorer II
    Yes, high quality industrial double-sided table like 3M VHB is available thick, like 1/4" or so. That will do what you want and last forever doing it. Another option is high-quality industrial Velcro which may even be better in this case.  Go to Grainger or Fastenal, not Hobby Lobby or Wal-Mart, and tell them what you want. It's available and will do what you need for this.
    • Almot's avatar
      Almot
      Explorer III
      Which one you think would hold it more steady, 1/4" double sided tape or same thickness Velcro?  I'm not worried about it falling down soon - maybe with time, when the glue deteriorates.  But I'm touching the amplifier often, adjusting the volume or flipping the switch on/off, it has no remote.  Volume and other controls are small, I don't want it to move/shake under my fingers.
      • PatJ's avatar
        PatJ
        Explorer II
        3M VHB tape holds the structure together in the world's tallest hotel, the Burj Al Arab in Dubai, UAE which has been standing since 1999. It holds the aluminum exterior skin on Walt Disney's concert hall in LA.  Heat from an RV will not be an issue. Strength over time (at least to 25 yrs) will not be an issue. Follow the instructions and enjoy.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
