Dick_A
Jan 02, 2016Explorer
Gerald, any welding supply should have the very flexible wire and terminals you need in bulk and should be able make the cables for you. Welding cable is very flexible as each size is made of a large number of small individual strands. The same gauge of regular cable is made using fewer strands of larger gauge wire. Welding cable is more expensive but is so much easier to work with in small areas.
Sorry this thread got so off topic - I should have noticed it earlier.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
