Almot
Jan 24, 2014Explorer III
Oasisbob wrote:
What about under the toilot vent cap?
No! Under the toilet flap in the bowl - you know, the one that opens when you flush it :D
Oasisbob - WHAT do you need to measure? The hot exhaust air from the fridge - then put it into fridge exhaust vent. The temperature of you coach before landing there - then put it on the coach. If you need to measure the fridge temperature - then put it in the fridge. If the outside temperature - then clip it in the shade outside, but not in the vents where warmer air is coming out, maybe under the frame somewhere.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
