RoyB wrote:
This is a neat shot from google search showing a pivot mount for their HDTV mount.
I like the idea of mounting to the inside of the storage bay doors. When bad weather comes up it is so easy to just swing it back inside the storage bay and close the door on it. You need something like this to able to walk away from the area and still have a TV when you get back...
All we do is use a two port transformer tap at the pedestal and hook the cable TV to it for the inside TVs and then run a 25-foot cable from the second tap under the the trailer to the area under the awning and use that for a small TV sitting on a table their...
Quick easy way to get setup for outside TV...
Roy Ken
Was looking at the bay the other day again and just by tapping around, it doesn't appear to be anything solid around it, especially the middle. I think the above idea might be the best solution.
