CA_Traveler
Aug 17, 2020Explorer III
Roof and portable panels are a great combination. Most lockers have a seal so you can use a connector inside and close the door on the wire. No need for 4/O welding cable.
For parallel panels they should be close to the same voltage. For serial they need to be the same amps and you'll need to insert the portable panels in the circuit unless you set up for serial/parallel. Just be sure not to exceed the controller specs.
