wintersun
Mar 08, 2021Explorer II
Tilting panels does not result in much gain unless you are in Canada and even then it is trivial most of the time. The panels are designed to work with sunlight coming into the cells at an oblique angle.
With them mounted on the roof you get charging 100% of the time, whether driving down the road or parked at a rest stop or when the RV is being stored. The most difficult part of the installation is running the large gauge cables from the solar charge controller to the batteries.
