obiwancanoli's avatar
obiwancanoli
Moving ahead with Satellite - Newbie questions
Hello all...
Recently picked up 1st Class A, a 2017 Newmar Ventana LE, and now getting around to researching Satellite & TV options, but there's literally everything I probably need to learn, and so, here I am, asking the experts. I also have a Winegard Trav'ler, with 2 cable ports.
In the exterior power cord compartment is a cable hookup. On the opposite side, another, paired with an HDMI port.
Inside, in a cabinet above the bedroom TV, is another cable connection port. There may also be a port above the cockpit, but I haven't looked for it. I've also watched TV using the rooftop antenna (free), and understand how to tap into that via tv settings, and channel search.
I'm soon to obtain service at home from Dish, and as many already know, cheaply add service to my RV. My query relates to a few things I'm just not clear on...
If cable is available at a typical RV park, do I have access to cable tv, via the existing cable wiring, and using the external port, or will I require a cable box -a Wally - to access service? If the proper source is chosen from the TV menu, is that all there is to it?
In order to watch the bedroom TV, will I need a separate "Wally" for access to the park's cable? I assume if I subscribe to Dish, they'll provide one for home, but not sure about a second, when I request service to the RV.
Will I be able to watch two different channels with two TV's, running one cable to the outside port in the power cable compartment? Or will I be required to use both ports on the satellite antenna, running one cable through an as yet unidentified point of access, say, to the bedroom TV?
Knowing as little as I do, are there more questions I should also have the answers to?
Thank you all for your guidance!
Michael
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 11, 2025
