phemens
Aug 17, 2020Explorer
time2roll wrote:phemens wrote:Victron has several to choose from. Only issue is if you will have a 12v battery buffer the converter needs to be rated for such. Any Victron should work as a direct power supply.
So if I do this, I guess I would need a 12v step-down converter to supply house 12v DC? Any recommendations?
Thanks, not sure what you mean by 12v battery buffer? When you say any Victron should work as a direct power supply, do you mean it can manage the step down directly or as a source to a step down converter?
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jan 16, 2025
