time2roll
Aug 18, 2020Nomad
phemens wrote:Victron has DC-DC converters to supply the 12v you need from a 24v source.time2roll wrote:Thanks, not sure what you mean by 12v battery buffer? When you say any Victron should work as a direct power supply, do you mean it can manage the step down directly or as a source to a step down converter?phemens wrote:Victron has several to choose from. Only issue is if you will have a 12v battery buffer the converter needs to be rated for such. Any Victron should work as a direct power supply.
So if I do this, I guess I would need a 12v step-down converter to supply house 12v DC? Any recommendations?
Battery as a 12v buffer might be for the emergency brakes but if the converter is sized properly no 12v battery should be needed.
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jan 16, 2025
