RLMiller
Aug 18, 2013Explorer
First of all there is some information missing? What is the voltage output of the two panels in series in full sunlight with an 8 amp load? Evidently the two panels in series produce 8 amps.
Assuming 30 ft (15’ x 2) #10 AWG from the panels to the controller the resistance in the wiring would be about .03 ohms (#10 AWG is .99 ohms/1000’). Discounting any voltage drop in connections, the IIR (current * resistance) loss in the wire would be about .2 volts, a negligible amount.
To put that in perspective, for my MH I have two 250 watt panels in series that produce 60 volts at 8 amps in full sunlight. The voltage drop with #10 AWG wire is negligible. The output from the MPPT converter to the battery can run as high as 45 amps so I use a short run of #8 THWN rated at 50 amps. Again the voltage drop is negligible. One concern is the maximum voltage that can be presented to the converter under a light, or no load condition. In my case the panels will produce about 80 volts with no load. Since my MPPT converter is rated at 100 volts so I’m well within specs.
While at a solar presentation in Quartzite earlier this year, the presenter was advocating very large wire sizes, with panels in series. I see no reason for that, unless you own copper stock, and my performance has demonstrated the wisdom of the lighter wire gauge and higher voltage.
To put things in perspective, I have two solar arrays that produce 2400 watts in each array for a total full sunlight output of 4800 watts. Since the two arrays with panels in series, produce 8 amps each, but at 300 volts, I can still use the #10 AWG wire for each array and stay within ampacity and voltage rating for THWN wire, with negligible voltage drop. The entire system is to code, and inspected by Building and Safety to permit Net Metering by the utility.
With my two panels delivering 500 watts, I have no problem running the satellite receiver, TV and some ham radios all day and into the evening. I use the generator for the coffee pot, or the stove, but the inverter will run the coffee pot, but the demand on the 12 volt battery is brutal.
Bottom line is you’re OK with the #10 wire from the panels to the converter, and in any case, the MPPT converters are quite tolerant of changes in voltage. You may now shift your brain to 'cool down' mode.
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
