Almot
Aug 18, 2013Explorer III
I forgot to tell 60V total array voltage - but does it matter? Any 2 panels in series will have more than enough voltage after MPPT controller to get 14.8V output. RLMiller - it's 70ft total 2-way run to controller, so the voltage/wattage drop is quite measurable though unlikely to disturb my comfort.
Hopefully I won't get that much with 480W array. Not because of controller 30A limit (too late, have bought it already), but because I won't have a load higher than 10-11 A at any given moment. Mostly it will be "pure charging" in 60-100% SOC range, so with 2% wire loss + 4-5% controller loss the battery+load won't have a chance to pull more than 31-32A.
0.6 Ah a day was an estimate. 150 AH from 480W array on a good summer day (if I get lucky), so with 0.75% difference in watts output between Option #1 and #2, it means 0.0075*150/2 (if half a day it hits 30A) = 0.6 AH difference in daily harvest.
I guess there is nothing to worry. Marc the Rogue ;) just put in standard warnings in case if somebody would try and run 100V*8A over AWG 12 or other crazy things.
Btw, have found AWG 8 with MC4 in 75ft and 100ft length. Temptation...
RLMiller wrote:
The output from the MPPT converter to the battery {with 500W array} can run as high as 45 amps
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 29, 2026
