KJINTF
Aug 19, 2013Explorer
My installation uses 15ft of #10 wires from a series parallel array of 2 each K135 and 2 each K140 panels. Array voltage stays in the high 30's close to the 40 volt mark with array current of as much as 15amps. The controller has about 6ft of #4 cables to the house batteries which are two CG batteries.
Not sure what you expect from your system a "Battery Charger" or a "Power Source" as I do. I regularly draw 30 or more amps from 12 Volt loads.
I will post a few graphs later today. Nice that the MS View application easily enables this stuff
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 29, 2026
