JiminDenver
Dec 28, 2014Explorer II
It is hard to pinpoint. I get high amps if the battery starts out really low or is sagged with a load. Then it will stay at peak until close to when it switches to absorb. I have also seen peak by applying a lower load slowly. I also saw over 16a on the 230w when I ran the 12v coffee maker test. The voltage stayed at 13.4v where I lowered it to get into bulk and the amps slowly rose to peak.
So as long as something kicks the controller into high gear, I see peak and can run close to peak in float if I carefully add loads up to the system max. The first time I ran the window shaker the float was set and stayed at 14.4v while the unit ran.
One of the 245w systems is gone and will be mounted on a van. That sold for enough to replace the panels. The other is spoken for but I'll believe it when I see the money. The 220w system will be a good solid 12a for anyone that needs the smaller footprint.
The more I look at high dollar controllers, the more I want to stay with the Eco-w's. I was set on the TS-MPPT-60 but it will be clipping if I mount three panels as it's limited to 45a in 12v. The TS-MPPT-45 couldn't even handle a pair of my 230w or the 245w's without clipping. I know it's not a issue for most with flat mounted panels but I would see 10a clipped all mid day. For the money that sucks. Three new Eco-w's would be $300 or less on auction, never see clipping and be more flexible, just with fewer features. Because of this indecision I will probably go with 250w polys that may need to be run off of the Eco-w's instead of 280-300w polys that would have to have a different controller. The $20 difference in price between the panels is nothing compared to buying the bigger controller.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Oct 16, 2022
