pianotuna's avatar
pianotuna
Nomad III
Dec 27, 2014
mppt or pwm An opinion from Victron
Hi all,
Victron, which makes high quality equipment, has charge controllers. At the end of an overview they give their description of the differences between PWM and MPPT. They do not support it with figures, but they don't get into any "hype" either.
Charge Controller
"PWM
The PWM charge controller is a good low cost solution for small systems, when solar cell temperature is moderate to high (between 45°C and 75°C).
MPPT
To fully exploit the potential of the MPPT controller, the array voltage should be substantially higher than the battery voltage. The MPPT controller is the solution of choice for higher power systems because of the lowest overall system cost due to smaller cable cross sectional areas. The MPPT controller will also harvest substantially more power when the solar cell temperature is low (below 45°C), or very high (above 75°C), or when irradiance is very low."
Here is a link to the "white paper" from Victron. It does have a lot more to say about the differences.
Basically MPPT is better than PWM in low light because panels can be placed in series.
White Paper MPPT or PWM
  • Hi KJ,
    The white paper goes into a lot more detail. I would rather pay for MPPT, but I probably can't afford a high amperage Victron controller.
  • PT
    Thanks for the link
    Always nice to read this kind of stuff
    Every manufacturer has their unique spin
