JiminDenver
Jan 12, 2015Explorer II
The buck convertor is exchanging the extra voltage for more amps, that's why I am getting the 20a extra. I wouldn't need it with a 12v system in PWM because at float voltage the panel is running efficiently and you get all of the power to use on a load. The battery wont accept the power but I can still use it either way.
Now does that mean MPPT is the best way to go, no it's just only thing to consider when designing a system. I use it because I ignorantly bought bought 24v panels to start with, for a year I wished I had bought 12v due to the cost of a MPPT controller.
Since they up'd the Voc spec on my controller I have been wanting to try a pair of 150w 12v panel in series vs my 24v panels. I am losing interest because of seeing the results from others doing the same with my controller as well as more respectable expensive controllers. What I am seeing is the conversion from a Higher Voc in the mid 40's to 12v isn't as efficient as a 24v panels mid 30's voltage. I'm seeing two 150w panels in series only producing a few amps more than my 245w panel. On a better controller I know of a 960w system using 160w panels in pairs for mid 40's producing 48a while I would expect 60a from four 250w 24v panels. Understanding the nuances can make a big difference.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
