CA_Traveler
Jan 12, 2015Explorer III
NinerBikes wrote:jrnymn7 Also it's not clear where the 44V came from. You need to divide by Vmp. Voc means 0A and hence 0W output from the panel.jrnymn7 wrote:
"I'm seeing two 150w panels in series only producing a few amps more than my 245w panel. On a better controller I know of a 960w system using 160w panels in pairs for mid 40's producing 48a while I would expect 60a from four 250w 24v panels."
That sure seems counter-intuative. One would think the 12v's in series, having a higher combined Voc, would result in even more wattage being used by the controller. I can see if the mppt was rated for 50v, and you threw 46 volts at it, but most buck converters boast ~98% efficiency, when operated within their duty cycle.
Does it perhaps have to do with the 12v 160w panels being in series, and thus their output would become 160w / 44v = 3.6a, as opposed to ~9a Isc?
320w/44v = 7.27a series 320w/22v =15.1a parallel.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
