Salvo
Jan 13, 2015Explorer
You are cherry picking and it has everything to do with low irradiance in the morning.
Yes, your discussion is about the controller. But it's nonsense discussing efficiency at max PV output when that only happens on a blue moon. For the majority of solar users here, the battery has the lowest SOC in the morning. At time there isn't enough irradiance to pump 30A into the battery. The battery will charge at perhaps 10A where charge controller efficiency is low. Surface charge will quickly increase battery voltage from say 12V to the 13V region, resulting in lower charge current.
12thgenusa wrote:
Not cherry picking at all. This has nothing to do with mornings, low irradiation, battery surface charge or what panels one has. This is about controller efficiency at various voltages.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
