MrWizard
Jan 13, 2015Moderator
you seem to be under the assumption that panel output is 14v instead of 17v ?
and doesn't get altered and processed to become 14+ charging volts
try measuring the panel voltage at the input of the controller
a shunt controller goes on off
a PWM controller "modulates" the voltage
i know you don't believe me , you think i'm wrong
test equipment will tell the truth either way
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
