jrnymn7
Jan 14, 2015Explorer
Seems to me, if using 12v panels, if all you ever did was bulk charging, you wouldn't need a controller at all. And if you were to de-rate the 12v panels to max out at say 14.8v, you could abs charge without a controller, as well?
And yes, I do realize at times there would be insufficient voltage available for charging, but in a pinch, say if one's controller crapped out, couldn't you just use a direct connection?
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
