BFL13
Jan 14, 2015Explorer II
My ASC solar controller had a reverse blocking diode in it. My Sharp 130w panel had place in the junction box where you could attach one to wire terminals. It also had two by-pass diodes already installed.
The advice in the manuals was not to use two reverse blockers at once, so if the panel had one you should remove it and let the controller's do it (since you can't remove the controller's)
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
