lorelec
Jan 17, 2015Explorer
Salvo wrote:
Right, Don needs to review that thread.
I think Rogue dropped his gains after the discussion from 20% down to 8%; but it's been a while.
No, it's entirely possible to get 20% gain with MPPT. Much more than that, actually, if you're using an array with a Vmp far above the battery voltage (which only MPPT controllers will allow you to do with any measure of efficiency). If you've been stuck in the boondocks for a long time, you might not realize that the popular thing to do these days is to use panels meant for grid-tie installations -- which do indeed have a higher Vmp than traditional panels meant for off-grid installs.
For CONSISTENT gain, with an array that has a Vmp closer to the battery voltage (17v Vmp, for example, with a 12v battery), around 10% is typical when you factor in the effects of temperature on Vmp. This is 1990's thinking, though. Time to move on.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
