BFL13
Jan 20, 2015Explorer II
Also you can't even set up the fair fight because you would have to pick the battery voltage you will be starting at. The lower the battery voltage the more amps you get from the MPPT.
At what battery voltage would it be a fair fight?
Salvo keeps saying his test only showed MPPT with about an 8% advantage, but his own test shows that the MPPT did 50% better!!!!
Of course that was early in the morning when PWM was 2a and MPPT was 3a. Later in the day when PWM was 8 and MPPT 9, that same 1 amp difference wasn't such a big percentage gain. You can make the results anything you want. Just pick the right conditions! :)
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
