KJINTF
Jan 22, 2015Explorer
All this has been gone over and over and over ..................
Many folks have tried to explain it several times
I do not remember the load / light conditions since it's been a few years - but look at the voltages. Vmp changes all the time temp/light conditions etc..... The buck conversion stage can easily be bypassed (a simple fet switch) if the panel voltage is low enough to cause the bypass - it will NEVER bypass in this setup. "Tracking" if that is what you folks are calling the MPPT mode is always active.
The picture shows "Battery" Current which is NOT true it should be labeled LOAD Current
