time2roll
Jan 30, 2015Nomad
jrnymn7 wrote:
Salvo,
Are you saying, because of its buck converter, if a small enough load is applied, during abs or float, the MPPT controller does not need to kick into full blown mppt mode, because the bucker itself can handle the increased demand? But if the load is too much for the bucker to handle, then it will kick back into full blown mppt mode?
Controller is just trying to hold the set voltage.
Controller will switch back and forth between MPPT and PWM as needed to hold the voltage.
Not really a big deal.
Same as your vehicle using cruise control downshifts as needed to make power to go up a hill.
Vehicle is just trying to hold the set speed.
