jrnymn7
Jan 30, 2015Explorer
Salvo said,
"Since mppt uses a buck regulator in its topology, it can operate in pwm mode while the panel voltage is higher than Vbat."
So you're saying... Since an MPPT controller uses a buck controller in its topology, IT (that is, the buck converter) can operate while the controller is in pwm mode, as long as Vpanel is higher than Vbatt.
