BFL13
Jan 30, 2015Explorer II
Ductape wrote:JiminDenver wrote:
That is because you are only applying a dollar symbol and not looking for the best tool for the job. The only time dollars should be a consideration is if you look at it and either would fill the need. That's when you look at the advantages and cost of each.
Exactly. If you are looking for maximum performance from a limited roof space for instance!
That can lead to having a number of smaller 12v panels instead of a few bigger 24v panels. But it does not tell you whether to put the 12s as 24 and use MPPT or leave them as 12 and use either PWM or MPPT.
