- jrnymn7Explorer$155 + $40 shipping = $195 - $175 = $20 extra for a completely user adjustable unit.
- BedlamModeratorShipping is a little steep on that one above. This one is $175 with shipping:
http://www.ebay.com/itm/231019238595?_trksid=p2060778.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
* I just found one of the above 30A controllers Amazon for an even better price. These are some interesting options... - CA_TravelerExplorer IIISounds like a plan. Keep on top of Craigs List and you might find a bargin.
- BedlamModeratorCan you point me to some cheaper model controller that would allow these 24V panels while keeping a 12V battery bank? A 60A Tristar just sold on eBay for under $500 but I'm not ready for that kind of financial commitment. I'll be able to draw off half a bank with the inverter for testing till I find something. I know this not ideal, but I can bank switch until I get this right.
- mena661ExplorerYou can get inexpensive DC to DC converters. I think 2oldman is running a 24V battery bank with a Victron DC DC converter for the 12V stuff.
- BFL13Explorer IIYou can't use the fake MPPT to go from 24 to 12v, it has no buck converter. The ones that say 12/24 can run a 24 panel but only to a 24 battery.
You can run 24v batteries on the trailer with a 24v inverter to get 120v from the inverter to the camper via a 120v cord. Now you need some 12v for the camper. Use the 12v batteries there and a charger powered by the 120v from the trailer.
Some of us tested the 12v inverter draw on a 12v battery bank to run the 120v converter in the trailer with no batteries hooked up. About 6 DC amps. Same as a television.
Experiment was for a "remote power supply" concept to run an RV with no batteries in the RV. Like those MHs that tow a cargo trailer done up with batteries, solar panels, controller and inverter, and a Honda gen, and whatever else. :) - BedlamModerator12 of the batteries will actually be going in to side boxes of my truck (Ram 5500) and be charged primarily by the dual alternators. The other 12 will be in an enclosed trailer with four 136W 24VDC panels keeping them charged. There will be an interconnect between the camper on the truck to the trailer, but I have not decided on an AC or DC connection. The batteries in the truck will be a parallel 12VDC connection to the camper.
Going to a higher voltage battery bank in the trailer will raise equipment cost for inversion to AC or stepping down voltage to 12VDC for use within the camper. I understand there is greater loss at lower voltage with higher amperage plus the requirement to larger cables, but am looking for an economic solution. If I can parallel two 24VDC panels into the cheap 30A MPPT controller I referenced to feed a parallel 12VDC battery bank, I think this will be a good start. I have a 2KW continuous use MSW inverter on hand for load testing. Once this system is up, I can continue scouring the web for upgrades without having too much invested in the initial install. Naturally as I find deals on more capable units, I may reconfigure the battery pack (for example a true sine wave inverter that accepts a higher input voltage). The idea of multiple charging sources being able to be used for all the batteries may limit my ability to go with higher voltage bank and not increase my cost beyond my budget.
The goal is to be able to run high wattage AC items for a minimum of a half hour and to have AC available to low wattage items (TV, chargers, mobile hotspot) for a minimum of six hours. - CA_TravelerExplorer IIIBedlam,
What is your power requirements and how/when do you plan to get there? 24 batteries is a long way from the cheap controllers you've posted as well as your panel postings. Aside from being free do you really have a plan/need to use all that power and weight? Or did I miss something? - CA_TravelerExplorer III
Bedlam wrote:
For now he's looking at 24V controllers. But 24 or 48 I'd go vertical with that many batteries. For 24V then 2x4 battery array 3 high.pianotuna wrote:
I agree 24 or 48 volts would be the route to follow for the battery bank.
Method 3 on the smart gauge site for the wiring. I.E. equal length cables from all jars to a buss. correctly interconnecting multiple twelve volt batteries
With 24 batteries that works out to six "strings" of four jars, assuming each jar is 12 volts. Voltage at the buss is 48.
I'm still trying to find a good price on better controller, but am trying out cheap ones while I wait for a deal.
http://www.ebay.com/itm/10A-20A-30A-12V-24V-Auto-Switch-MPPT-Solar-Panel-Regulator-Charge-Controller-LN-/231464958089?pt=LH_DefaultDomain_0&var=&hash=item7b91b49fa8
Having RV issues? Connect with others who have been in your shoes.24,259 PostsLatest Activity: May 27, 2025
