pianotuna
Mar 21, 2019Nomad III
The 15 K is 10% more cooling. I'd stay with the 13500. I would use #10 wire for the install. I'd even consider dropping the size down to 11000 btus. I'd also consider a heat pump unit.
In many older campgrounds the pedestals only have 15 amp "additional" outlets. That makes running the 15k unit "iffy".
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
