dougrainer
Mar 26, 2019Nomad
3 tons wrote:dougrainer wrote:pianotuna wrote:
I'd go for 13500 as they can be run on a 15 amp circuit.
A 13.5 Brisk air pulls 13.1 amps at 95 degrees.
A 15k Brisk air pulls 14.2 amps at 95 degrees
So, why can't you run either on a 15 amp circuit????????????? Doug
Doug, my Coleman 11k Mach 1 P.S. is rated at 9.0 running amps with Lo-fan, but using a clamp-on meter (on source hot wire), I consistantly measure about 11.6a...Can you suggest a way to measure for winding leakage?
Thanks
No, I have no way to determine leakage Never heard that term or problem. YOUR RVP is a specific LOW amp RVP designed for 30 amp dual AC systems. The OP was asking about Dometic systems. Doug
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
