dougrainer wrote:
When you install ANY type Insect screen over the outside refer vent, you cut the air flow volume by about 50%. Big deal? Yes, when it gets over 70 degrees outside. Reduced fresh air flow over the refer Condenser coil will inhibit correct cooling. IF Insects make a nest on the refer burner it is easy to fix. Think about this when you decide to install the screens. Doug
Not if the screen is designed correctly.
My furnace screens are convex. With a convex shape the total screen opening equals the opening without a screens installed.
