swimmer_spe
Jan 30, 2019Explorer
BFL13 wrote:swimmer_spe wrote:BFL13 wrote:
I think it all depends on what you are going to run with them in parallel. I am only familiar with paralleling different capacity size house batteries for RV deep cycle use.
Somebody who knows about starting batteries and your intended use needed here!
All it is for it to run some lights. Basically, I have an old trailer on blocks and for the summer, at night when it is still too hot for fuel lights, I want to turn a switch for light.
That should work IMO, but old time lights add up. 3 amps for two bulbs. You have "several" batteries, so if you had two little ones you could parallel them as one bigger 12 and parallel that with a full size 12. That would put less strain on any one little one.
The main light I run is a 12v florescent light. That and a single outside light.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
