- jaugustonExplorerA lot of trouble for what I would seem to see as a non-problem. The water pump should have a pressure switch that shuts it off when there is no demand for water. If it doesn't there is likely something wrong with the pump. We have a ice maker in out refer and that requires that the pump is always on when not hooked up to shore water or it screws up the ice maker.
- Chris_BryantExplorer IIIntellitec water pump controller-each switch is momentary to ground, so only a single wire is needed to each switch.
- Horizon170ExplorerYou can parallel as many switches as you want. The only problem is you will have to cut OFF the one you used to initially cut it ON with.
I see no advantage to multiple switches. - dons2346ExplorerYou will need to install a latching relay. You will also have to change out your current on/off switch to a momentary on style. With the relay, you push the switch to turn on power to the pump and then you push it again to turn it off. Your second switch location will also have to be a momentary. Wired correctly, you can turn the pump on at one location and turn it off at the other or vice versa
- BumpyroadExplorer
DaddyLonglegs wrote:
My water pump currently has one on-off switch. I would like to be able to turn it on-off from several different spots on the TT. What would be the easiest way to accomplish this?
no easy way to duplicate/triplicate switching if you want switches to work like two way or three way in a house. not so hard if you are willing to just add additional switch wires and run them to various locations each to work independently.
bumpy - Vet_ManExplorerLeave the pump on while using the TT, and not hooked to city water. It does not run unless you open a faucet.
- newman_fulltimeExplorer IITurn the faucet on door off
Having RV issues? Connect with others who have been in your shoes.24,322 PostsLatest Activity: Nov 09, 2023
