NinerBikes
Aug 23, 2015Explorer
There's no way I'd want that little Fumoto valve and it's inhibited flow rate sitting on the bottom of my oilpan when doing an oil change. I want the big hole and the high volume flow rate to take and carry all the heavy stuff downstream and out of the oil pan with the oil as it drains, instead of the possibility of it settling. Not on an expensive motor like that. Leave it as the engineers designed it, pull the plug and let it all flow out like a raging river.
Why aren't you buying your motor oil by the 5 gallon pail?
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 30, 2026
