GlennLever
Aug 25, 2015Explorer
I received these ramp plans from a friend.
Although they were not needed to do the oil change, and they are sizable (storage) I think I will build a set.
This was his commentary.
"I made (4) of the ramps several years ago and they continue to work as planned. I use them to raise the front for gen and axle service and raise the rear for rear end service. The 4x4 block on the end keeps you from driving off the ramps. Counting the steps going up the ramps is also a good indicator of where you are. I'm now able to use the ramps without an extra set of eyes outside watching my position. "
I asked his permission to post the plans, he wanted me to added.
"a friend provided these plans. He accepts no liability for use or construction. In other words construct and use at your own risk."
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 30, 2026
