DustyR
May 13, 2016Explorer
Bear Ghost wrote:myredracer wrote:Bear Ghost wrote:
Or should I tighten the castle nut to get to the next available hole?
Did you use a torque wrench on the axle nuts to get them seated first, then back them off? You should never tighten them to get to the nearest hole. They need a small amount of free play.
Yes I used a torque wrench set at 50 lbs and torqued the nut, spun the hub, torque/spun 2nd, 3rd time, then loosened the nut and tightened with my fingers. Had to back it off slightly to get a cotter pin hole.The nut moves with only the cotter pun holding it. But that's were I get a fraction of wobble with the tire installed.
The slight wobble is a caught-22. This is what the manufacture recommends, the general consensus is better slightly loose than too tight.
Having RV issues? Connect with others who have been in your shoes.24,378 PostsLatest Activity: Apr 12, 2026
