Lynnmor
May 13, 2016Explorer II
Sounds like you did it right. You should not be tightening the nut unless the wheel is spinning. When the wheel stops, do not let the wheel rotate at all while backing off all the torque and then adjusting. Rotating the wheel will only roll the grease back in and somewhat reduce the feel for the adjustment. Yes, there will be a slight amount of play in the bearing, you are looking for the minimum amount of clearance possible.
Having RV issues? Connect with others who have been in your shoes.24,378 PostsLatest Activity: Apr 12, 2026
