free radical wrote:
I guess its too late now since you already have the foam,
however this would be much easier to do this with one of those guns that you screw the expanding foam can into,,
Its just a handle with trigger and about foot long nozle,,gives excelent control as you can spray it very slow or fast and stop anytime..
Hint..to screw the expanding foam can onto this it helps to spray WD 40 onto the gun tread..
Also theres a special cleaner sold in presurized cans to clean the nozle after
All these are sold in Home depot or most hardware stores..
Those cans would not be able to go down all the way to the bottom, I bought about 6 of these cans and I will do the parts that I can't pour into (higher parts of the lower wall), simply drill a hole and stick the nozzle in, only small areas at a time so the expension doesn't warp my outside panels.
