MEXICOWANDERER's avatar
Nov 03, 2015
My New LED Light Bar Specs
SPECIFICATION :
1.LED Power: 400W
2. Operating Voltage: 9-32V DC
3.Waterproof rate: IP 68
4.80pcs*5w high intensity LEDS
5. Body Color: White
6. New Cree Convex Lens
7.Material:Material: Hi-impact Aluminum Housing
8.Lens material:PMMA
9.Mounting Bracket: Stainless Mounting Hardware
10.Life Span:50000H
11.Dimensions:42inch
12.Amp Draw(DC):33A /12V , 17A / 24V
13.Beam Type:: Spot &Flood Beam Combo (12F/56S/12F)
14.Theoretical Lumens Output: 40000LM
15.Operating Lumens Output: 36000 LM
16.Weight: 6kg (Per Unit Included The Box)
17.Size:1059x88x78mm
18.The high performance of tight waterproof,dustproof,quakeproof.
19.Anti explosion
Naw, it ain't a joke. New technology OSRAM chips. Gotta feed this mutha with 10 gauge wire. An 80-ampere TYCO relay is on the way. The light this bar produces is insane. No using in hilly or curvy conditions. Dim lights when oncoming car is 2 miles away (another - not a joke). Dang near weaponized lighting.
  • Cool project, Mex!
    The other neat thing about LED's is watching the confusion in the bulb Dept at Home Depot. The rapid changeover to LED technology has left most consumers looking for help when purchasing new bulbs.
  • I too love LED lights. I used to be rather heavy into hobbyist side of design and engineering, not so much now. In the good old days, I had phone numbers for engineers at Lumileds and got to test some of their products before commercial release, they had an office only a few hours from here and would actually stop to say hi when passing through town ... then they got bought out by Philips, reorganized and well, I was told I could buy my samples like everyone else :)
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    I remember when LED's were dim little things you had to shade to see if they were lit.. Just now I have a 5 meter sliced and diced strip in one of the fixtures (Formerly Florcesent twin 15 watt) this thing runs on a 7 watt wall wart (or in my case on house power) and I do believe it's way more light than the 30 watts of florcesent's it replaced.
    Keyboardist at Church sits in a kind of dark corner and complaned about the lighting.. So last week I took in a shorter strip and plugged it in and.. Lit up her life.. I think the strip is around 3 watts. The light around 60 (incandescent equivalent) Modern LEDs are IMPRESSIVE and they are improving them daily.
  • Phish Network No.
    See those mounting ears?
    Going to be replaced with 1/4" stainless feet
    Torx security bolts.
    Stainless 1/4" nutserts into the roof also using torx security dome head bolts.
    Red locktite.
    The Spandex cover is being custom sewn up as I type. I need to get some polyethylene cross-link wire to run up the door post. Tough insulation.
    Push-push stainless button switch on dash. Push to enable Klingon Disruptor with high beams, push again to disable. Latching relay to control Bosch relay.
    PROVEN. Lit up a yellow diagonal highway sign at 2.3 miles. Eduardo said he could see the sign at 3.1 miles but it was lost to my eyesight. I definitely can see any color cow at +1.0 mile, even those 50' off the pavement. Freakin' light is amazing.
    The Spandex cover, plus a disconnected weatherproof socket and plug makes me immune to CHP tickets when I cross into revenue enhancement land. A hundred watt motion detector with 105db screamer will give the light-fingered light and music to dance by in my driveway.
    But the Borg comes first the Disruptor can wait.
  • 100lm/watt sounds about right for "new" chips. I wonder however is the rating in ANSI lumens or Peoples' Republic most-honorable lumens?
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
